Configure the SNMP table of filter profiles to determine whether particular management targets receive particular notifications.
  1. In the navigation pane, expand Configuration > Edit > SnmpV3.
  2. Select Notify Table.
  3. Select the Notify Filter Table tab.
  4. Select Insert.
  5. In NotifyFilterProfileName, type a name for the notify filter profile.
  6. In Subtree, type the subtree location information in x.x.x.x.x.x.x.x.x.x. format.
  7. In Mask, type the mask location in hex string format.
  8. From Type, select included or excluded.
  9. Select Insert.
Notify Filter Table Field Descriptions
Use the data in the following table to use the Notify Filter Table tab.
Name
Description
Specifies the name of the filter profile used to generate notifications.
Subtree
Specifies the MIB subtree that, if you combine it with the mask, defines a family of subtrees, which are included in or excluded from the filter profile. For more information, see RFC 2573.
Mask
Specifies the bit mask (in hexadecimal format) that, in combination with the subtree, defines a family of subtrees, which are included in or excluded from the filter profile.
Type
Indicates whether the family of filter subtrees are included in or excluded from a filter. The default is included.
